Description
Orange Pi 5 Plus uses an 8-core 64-bit Rockchip RK3588 processor, consisting of a quad-core A76 + quad-core A55, with an 8nm technology process, a main frequency of up to 2.4GHz, integrated ARM Mali-G610, built-in 3D graphics processor, compatible with OpenGL ES1.1/2.0/3.2, OpenCL 2.2 and Vulkan 1.2; integrated NPU supports mixed computations INT4/INT8/INT16/FP16 with a computing power of up to 6 TeraOPS, which can meet the needs of most end devices in advanced computing; 4GB/8GB/16GB LPDDR4 memory and an eMMC socket, to which an eMMC module with a capacity of 16GB/32GB/64GB/128GB/256GB can be connected. Orange Pi 5 Plus supports Orange Pips, the official operating system developed by Orange Pi, as well as Android 12, Debian 11, Ubuntu 22.04, and other operating systems.
Orange Pi 5 Plus provides a variety of interfaces, including two HDMI output ports, one HDMI input port, two PCIe extended 2.5G Ethernet ports, an M.2 M-Key slot supporting NVMe solid state drives installation, and an M.2 E-Key slot supporting Wi-Fi 6/BT modules. Additionally, Orange Pi 5 Plus is equipped with two USB 3.0 ports, two USB 2.0 ports, and two Type-C ports (one of which is a power connector). Orange Pi 5 Plus has a wide range of applications, helpful for enthusiasts studying embedded systems development, as well as suitable for enterprises developing mini machine vision systems with multiple Ethernet ports. Orange Pi 5 Plus offers enhanced high-class application performance to meet the customization needs of products in various industrial sectors.
Characteristics
Processor:
SoC
• Rockchip RK3588 (8nm LP process) (8-core)
CPU
• 8-core 64-bit processor
• 4 x Cortex-A76(2.4GHz), 4 x Cortex-A55(1.8GHz) and separate NEON co-processors
GPU
• Arm Mali-G610 MP4 “Odin” GPU
• Compatible with OpenGL ES1.1/2.0/3.2, OpenCL 2.2 and Vulkan 1.2
• 3D graphics engine and 2D graphics engine
NPU Embedded NPU supports INT4/INT8/INT16/FP16 mixed operation, with up to 6Tops computing power
PMU RK806-1
RAM 4GB/8GB/16GB(LPDDR4/4x)
Memory
• eMMC socket: 16GB/32GB/64GB/128GB/256GB eMMC module can be attached
• QSPI Nor FLASH 16MB/32MB
• MicroSD (TF) Card Slot: up to 128GB
• M.2 M-KEY Socket
USB
USB3.0 × 2
USB2.0 × 2
Type-C ×1
Type-C (USB3.1) Ч1
Video Output
• HDMI2.1, up to 8K @60Hz
• DP1.4 (DisplayPort), DP1.4 and USB3.1 ports are multiplexed, and the port is shared with Type-C
• 2 * MIPI D-PHY TX 4Lane, configurable up to 4K @60Hz
Camera
• 1XMIPI CSI 4 Lane
Audio
CODEC: ES8388
• 1xAudio 3.5mm jack with mic
• 1xMIC In
• 1xHDMI 2.1 eARC
• 1xSPK
Ethernet
2xPCIe 2.5G LAN(RTL8125BG)
Expansion Port
40Pin dual row pins with the following multiplexing functions: UART, I2C, SPI, CAN, I2S, PDM, AUDDSM, SDIO, PWM, GPIO
M.2 2280 slot for NVMe SSDs (PCIe 3.0 x4) up to 2,000 MB/s
M.2 connector E key (top) for connectivity with PCIe 2.0 x1/PCM/UART/USB2.0,2230 Wi-Fi6 /BT supported
Button
1×MaskROM key
1xRecovery
1×on/off key
Power Source
Support Type-C power supply, 5V @ 4A 20W
Debugging
3 Pin debug serial port (UART)
RTC
2Pin: RTC backup battery
Supported OS: Orangepi OS(Droid)、Orangepi OS(Arch)、Ubuntu、Debian、Android12
