STM32 Programming. Part 11: Copying Arrays via DMA
Posted: 17 Oct 2023, 04:36
In this short article we will look at the MEM2MEM mode and learn how to copy one memory location to another using DMA. All examples are, as always, for the stm32f103c8 microcontroller.
MEM2MEM mode has three features compared to normal DMA operation when we send any data to or receive anything from a peripheral:
  1. MEM2MEM mode does not require any request from the peripheral modules. Once the DMA channel is enabled, the transfer process starts immediately.
  • The memory address register DMA_CMARx and the peripheral address register DMA_CPARx are populated with memory area addresses.
  • MEM2MEM mode and CIRC ring mode cannot be used at the same time.
So here we go! For MEM2MEM transfer you can use any free DMA channel, for examples we will choose the 1st one. Let's create 2 arrays data[] and buff[]:
uint8_t data[10];
uint8_t buff[sizeof(data)];
We will copy data[] to buff[] via DMA. Initialize the arrays in this way:
for(int i=0; i<sizeof(data); i++)
data = i+1;
buff = 0;
Don't forget to enable DMA1 clocking and disable the selected DMA channel just in case:
RCC->AHBENR |= RCC_AHBENR_DMA1EN; //Enable DMA1 clocking
  DMA1_Channel1->CCR &= ~DMA_CCR_EN; //Disable the channel before tuning.
Configuring the transfer registers:
DMA1_Channel1->CNDTR = sizeof(data); //how many elements to copy
  DMA1_Channel1->CMAR = (uint32_t)(data); //what we copy (memory address)
  DMA1_Channel1->CPAR = (uint32_t)(buff); //where we copy (address of "periphery")
DMA channel setup:
  DMA1_Channel1->CCR =.
      DMA_CCR_MEM2MEM //from memory to memory
    | DMA_CCR_MINC //memory increment
    | DMA_CCR_PINC // peripheral increment
    | DMA_CCR_DIR; //direction from "memory" to "peripheral".
Pay attention to the direction of data transfer. Since we have entered the address of the array we are going to copy into the memory address register, the direction of data transfer is from "memory" to "periphery". Also, in comparison with the "normal" mode of DMA channel operation, here we use both memory address increment and peripheral address increment.
You can start the process with this line:
DMA1_Channel1->CCR |= DMA_CCR_EN; //start the process
Full function code:
uint8_t data[10];
void main()
    data[i] = i+1;
    buff[i] = 0;
  DMA1_Channel1->CCR &= ~DMA_CCR_EN; //Disable channel before tuning
  DMA1_Channel1->CCR = (uint32_t(buff); //where we copy (address of "periphery").
    | DMA_CCR_DIR; //direction from "memory" to "periphery"
  for(;;)
If you look at the values of data[] and buff[] arrays in the IAR debugger, they had these values before DMA-copying was started:
Viewed 28880 times
and after the process is complete, it's like this:
Viewed 28880 times
It's all working!
It's worth noting that if instead of
  DMA1_Channel1->CMAR = (uint32_t)(data); //what we copy (address of "memory")
do it like this:
  DMA1_Channel1->CMAR = (uint32_t)(buff); //where we copy (address of "memory")
  DMA1_Channel1->CPAR = (uint32_t)(data); //what we copy (address of "periphery")
and remove DMA_CCR_DIR in DMA channel initialization:
    | DMA_CCR_PINC; //increment of peripherals.
Then everything will work exactly the same way.
