Arduino mini-lessons
  • Peripheral devices such as timers and counters play an important role in microcontrollers, providing the ability to control time intervals, periods, and events. In this lesson, we will explore how to work with timers and counters on the Arduino platform, as well as provide practical examples and explanations on how to connect them.
    Basics of working with timers and counters
    Timers and counters are hardware devices designed for generating precise time intervals or processing events. They typically have registers for setting parameters such as frequency divider and operating mode. Arduino provides libraries and functions to simplify working with these devices.
    Connecting and configuring timers on Arduino
    Special registers are used to work with timers on Arduino, allowing you to configure the operating mode, frequency divider, and counter. Let's consider a practical example of generating a delay using a timer:
    const int ledPin = 13;
    pinMode(ledPin, OUTPUT);
    // Setting up timer 2 for generating a delay
    TCCR2A = 0; // Normal mode
    TCCR2B = (1 << CS22) | (1 << CS21) | (1 << CS20); // Divider set to 1024
    TIMSK2 = (1 << TOIE2); // Enable interrupt on overflow
    ISR(TIMER2_OVF_vect) {
    digitalWrite(ledPin, HIGH); // Turning on the LED
    delay(1000); // Delay of 1 second
    digitalWrite(ledPin, LOW); // Turning off the LED
    // Other tasks can be performed here
    Generating signals using timers
    Timers can be used to generate signals of a specific frequency. Let's consider an example of blinking an LED using a timer:
    // Setting up timer 1 for signal generation
    TCCR1A = (1 << COM1A0); // Clearing on compare match with OCR1A
    TCCR1B = (1 << WGM12) | (1 << CS10); // CTC mode and divider set to 1
    OCR1A = 15624; // Value to achieve a frequency of around 1 Hz
    Using counters
    Counters allow tracking the number of events or pulses. For example, you can create a counter to count button presses:
    const int buttonPin = 2;
    volatile int buttonCount = 0;
    pinMode(buttonPin, INPUT_PULLUP);
    attachInterrupt(digitalPinToInterrupt(buttonPin), countButton, FALLING);
    Serial.begin(9600);
    // Printing the counter value to the Serial Monitor
    Serial.println(buttonCount);
    delay(1000);
    void countButton() {
    buttonCount++;
    Conclusion
    Working with timers and counters on the Arduino platform provides the ability to precisely control time intervals and events. We have covered basic examples of using timers and counters, as well as understood how to connect and configure them on Arduino. These skills will be useful when creating various projects that require time synchronization and event processing.
  • In this lesson, we will explore how to work with Analog-to-Digital Conversion (ADC) and Digital-to-Analog Conversion (DAC) on the Arduino platform. These processes allow the microcontroller to interact with analog signals and create analog outputs, which can be useful for a variety of applications.
    ADC enables the conversion of an analog signal, such as voltage from a sensor, into a digital format that can be processed by the microcontroller. Arduino typically has several analog pins where analog signals can be measured.
    Example of working with ADC:
    const int analogPin = A0; // Analog signal pin
    Serial.begin(9600);
    int analogValue = analogRead(analogPin); // Read analog value
    float voltage = analogValue * (5.0 / 1023.0); // Convert to voltage
    Serial.print("Analog Value: ");
    Serial.print(analogValue);
    Serial.print(", Voltage: ");
    Serial.println(voltage);
    delay(1000);
    Digital-to-Analog Conversion allows creating analog output signals controlled by the microcontroller. Arduino does not have a built-in DAC, but you can use techniques to approximate an analog signal.
    Example of working with DAC (PWM): changing the brightness of an LED
    const int ledPin = 9; // PWM pin
    int brightness = 0; // Initial brightness
    int fadeAmount = 5; // Brightness increment step
    analogWrite(ledPin, brightness);
    brightness += fadeAmount; // Increase brightness by step
    if (brightness <= 0 || brightness >= 255) {
    fadeAmount = -fadeAmount; // Change the direction of brightness change
    delay(30); // Delay for a visible brightness change effect
    Conclusion
    Working with analog-to-digital and digital-to-analog conversion is an important aspect in many Arduino projects. We have covered the basics of using ADC for measuring analog signals and applying PWM for creating analog outputs. These skills open up possibilities for creating more complex and interesting projects involving analog data processing and controlling analog devices.
  • In this lesson, we will explore how to work with UART/USART, I2C, and SPI on the Arduino platform. These protocols provide the ability to exchange data between microcontrollers and other devices, which can be useful for creating a variety of projects.
    1. Working with UART/USART:
    UART (Universal Asynchronous Receiver-Transmitter) or USART (Universal Synchronous Asynchronous Receiver-Transmitter) are standard serial communication methods used for transmitting data between devices. Many sensors, modules, and computers support UART communication.
    Example of working with UART:
    Serial.begin(9600); // Starting UART communication at a speed of 9600 bits per second
    if (Serial.available()) { // If data is available for reading
    char data = Serial.read(); // Read the data
    Serial.print("Received: ");
    Serial.println(data);
    2. Working with the I2C protocol:
    I2C (Inter-Integrated Circuit) is a communication protocol that allows multiple devices to be connected to a single bus. I2C is used for data exchange between microcontrollers and other devices, such as sensors, displays, and more.
    Example of working with I2C:
    #include <Wire.h> // Include the Wire library for working with I2C
    Wire.begin(); // Initialize the I2C bus
    Serial.begin(9600);
    Wire.beginTransmission(8); // Start the transmission to the device with address 8
    Wire.write('A'); // Transmit the data
    Wire.endTransmission(); // End the transmission
    delay(500);
    Wire.requestFrom(8, 1); // Request data from the device with address 8
    if (Wire.available()) {
    char data = Wire.read(); // Read the data
    delay(1000);
    3. Working with the SPI protocol:
    SPI (Serial Peripheral Interface) is a synchronous communication protocol between a microcontroller and peripheral devices. It is used for data exchange with various devices such as displays, sensors, radio modules, and more.
    Example of working with SPI:
    #include <SPI.h> // Include the SPI library
    const int slaveSelectPin = 10; // Device select pin
    SPI.begin(); // Initialize SPI
    pinMode(slaveSelectPin, OUTPUT);
    digitalWrite(slaveSelectPin, HIGH); // Disable the default device
    Serial.begin(9600);
    digitalWrite(slaveSelectPin, LOW); // Enable the device
    SPI.transfer('A'); // Transfer data over SPI
    digitalWrite(slaveSelectPin, HIGH); // Disable the device
    delay(500);
    char data = SPI.transfer(0); // Receive data from the device
    delay(1000);
    Conclusion:
    Working with UART/USART, I2C, and SPI are key skills that open up a lot of possibilities for data exchange between microcontrollers and other devices. We have looked at examples of working with each of these protocols on the Arduino platform, which will allow you to create more complex and interesting projects by interacting with various devices and modules.
